Quote: Michael is the A7-LK the threaded adjuster plate/seal assy? How much does it run? EDIT meant the A7-RK as it goes on the pass side.
I don't think you can buy the endplates anymore unless the aftermarket started making them again in the last year or 2 , you need to find good used ones or old MP kits to get them now .
