I cheated when I did mine.
Freeze the bushing. Clean the hole in the crank and make sure it's got a chamfer. Once it's prepped, hang a balancer puller off the crank. Slide the frozen bushing between the crank and puller. Use a plate between the ram and bushing. Crank away but do it before the bushing thaws out.
This is just a random photo of the puller I grabbed from the net. I have a pic of my install at home but I'm not sure if it's on my current hard drive or the one that fragged.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
