I have a hole in the bellhousing that I can use a garden sprayer or hose to spray water onto the torque converter while running the motor in nuetral for the late rounds
applying water to the trans & converter is what i had in mind. i have a garden tap in my pit space so was considering using it to do an extra cool as you said. i already have a fan assisted trans cooler but the heat catches up in the later rounds.
