I actually have some steel plates that were isolators I guess that look just like that plate except thinner and square on both ends. I assume this has the spreadbore on one side?
I had my carb on there already with just the square gasket and it seemed to work fine but I just wasn't sure which gasket to use or if using the square gasket on that spreadbore would cause the fuel/air to not disperse correctly.
