Re: Comp 324, .650 lift solid cams. Do you use,like'em?
[Re: 6PACMAC]
#889049
12/27/10 07:23 PM
12/27/10 07:23 PM
Posts: 31,077 Oregon
AndyF
Oregon
That cam has a ton of duration. I've never used anything that large before in any of my dyno testing. Guess maybe I should try it some day just to see how it stacks up.
My 514 engine makes about 850 hp with a cam that is only 266 at 050. So I'm not sure why I would need 24 more degrees of duration?
440Jim is running the Comp MM 305 which is 279 at 50 on the intake side with .650 lift. So the 324/.650 has the same lift but another 11 degrees of duration at 050. I'm not sure that adding that much duration to a car like Jim's would make him quicker. In fact, it might make the bottom end soggy and slow him down?
I think the reason that cam is so big is because it was designed to work with ported 452 heads that didn't really flow all that well. At least that is what I was always told. Like I said, I've never put it on the dyno to see how it compares to a more aggressive cam like the MM 305.
Entire Thread
6PACMAC
12/27/10 03:46 AM
CHAPPER
12/27/10 03:58 AM
Bighead440
12/27/10 03:59 AM
540dust
12/27/10 05:17 AM
sixpakdodge
12/27/10 06:21 AM
6PACMAC
12/27/10 10:30 PM
n20mstr
12/27/10 10:37 PM
MIKES_DUSTER
12/27/10 10:40 PM
BradH
12/28/10 04:22 PM
AndyF
12/27/10 11:23 PM
rowin4
12/27/10 11:48 PM
Sport440
12/28/10 12:12 AM
ProSport
12/28/10 01:07 AM
moparniac
12/28/10 01:19 AM
turboplymouth
12/28/10 01:33 AM
Maximus_Wedges
12/28/10 02:52 AM
AndyF
12/28/10 05:47 AM
540dust
12/28/10 06:31 AM
nss guy
06/28/16 02:59 AM
440Jim
06/29/16 05:18 PM
Ray408G3Hemi
07/28/19 06:37 PM
rb446
07/29/19 09:51 AM
BradH
07/29/19 05:17 PM
Scott440
06/21/16 08:45 AM
440Jim
06/23/16 03:29 PM
Eric
06/23/16 07:38 PM
BradH
06/24/16 01:41 AM
rb446
06/24/16 03:22 AM
gregsdart
07/30/19 06:43 PM
fast68plymouth
07/31/19 06:41 PM
AndyF
08/01/19 05:42 AM
Eric
06/22/16 05:17 PM
rb446
06/22/16 08:36 PM
06/23/16 03:00 AM
EDDIEB
06/27/16 03:12 AM
DrCharles
06/27/16 06:09 PM
Thumperdart
06/27/16 07:37 PM
AndyF
06/27/16 06:15 PM
DrCharles
06/27/16 08:13 PM
Thumperdart
06/27/16 08:34 PM
DrCharles
06/27/16 08:58 PM
DARTH V8Я
06/27/16 09:05 PM
Thumperdart
06/27/16 09:29 PM
BradH
06/28/16 02:38 AM
eds dart
06/28/16 04:30 AM
fast68plymouth
06/28/16 04:51 PM
sasquatch
06/28/16 09:19 PM
