Looking to see how you guys have set up your small block tunnel ram fuel lines with a mechanical pump....?????
I'm going to run (2) 500 Edelbrock Thunder Series AVS single feed carbs in-line on a Weiand Tunnel Ram from a Carter performance series mechanical pump with alternator in the stock location.
Street 408 stroker....I was planning on not running a regulator....?????
Rickster
are you sure a mechanical pump will be enough for 2 carbs at high rpm? or is this your grocery getter?
Yes it will be mostly street driven and yes the Carter pump will feed the 408 with no problem.....it's doubtfull this motor will ever see 6000rpm, but it's sure to have plenty of torque
Now go play with your squirrel
Rickster
