Two things come to mind to me from how you describe it. Either the lock-up is coming on in 1st which would feel like putting a manual trans in high gear at such a low speed. The other is a 2 gear applied fight or in other words 2 gears applying at the same time. Does it make the eng stall right away and feel like you slammed on the brakes ?? Ron
