Thanks for the info. I have not hooked the scanner to it yet because the CEL is not on, but it still may have some codes. The speed sensor is so easy to replace and cheap so I might just try one anyways. It is funny that I never had this problem until I put the new sensors in the vavle body.
Where did you get the sensors? just because they are new does not mean they are good .
