If you change your fuel line to 1/2" the stock & Hi-Perf mechanical pumps can't keep the fuel pressure up for very long without adding a pusher pump; the Carter or the Holley Blue are plenty adequate for that. For 5/16 or 3/8 fuel line, a good mechanical pump alone should be plenty.
