Also, check the trans cooler for flow, they will block and the trans temp sensor will disengage the od and turn the od off light on Thad
Dirt and crap will build up over time in the rad/transmission cooler fins. I'd spend alot of time and water washing and blowing out all the fins from both sides. Run the water until it turns clear.
There is a check-ball also that is known to stick and block flow to the cooler. You could try having a look at that next.
Your truck did exactly what it is supposed to do if the transmission is getting too hot, it's in the owner's manual. Be thankful it's set-up to protect itself from melting. Don't give up on it.
Mo' Farts
Moderated by "tbagger".
