I need to replace the power steering hose on my car and I bought one from NAPA and it does not seem to be the correct one, or I should say that the one that I bought does not match the one that is on the car. Could someone post pictures of what each end should look like so I can determine which hose that I have is correct?
The hose that I am referring to is the one with fittings on both ends. I believe that I have the Saginaw type pump and both of my current hoses (NAPA new and existing) measure around 28" long. I have looked up the hose on YO and they show that they should be 35" long so I am confused which one I should have for the car.
