In a class full of millionaires there are no lazy, ignorant miscreants. They are all overachievers in their chosen fields. It is no longer a plug and play class where you buy an engine from RBRE and Ray tells you what gear and convertor to run and you adjust the valves once a weekend. It is Pro Stock Jr. where you tear the car apart every round. Clutch management is where CW excels. David has it figured out now but he can only work on so many cars at each race.
