dont have a pics of the tool but what you can do is raise the piston to TDC and put a valve stem with a fine point (machined center obviously)(the tool) in the valve guide in the head and "knock" it into the piston to give a valve center location and give piston to machine shop... or use an in head piston cutter
maybe a pro here will give ya a better advice or technique...
Mopar Performance
