Sometimes it's not good being the first to reply on these nitrous threads. ...................................i prefer NGKs for the simple reason their more forgiving , nip a strap on an autolite & you've possibly damaged a piston , the NGKs are a bit like a fuse , genarally speaking you will loose a ground strap before a piston.
