Don its a 440source kit and since I will use the EZ heads I plan on the Indy dual plane intake for now as it can be made to Max Wedge size.
Mike I dont want to run a roller because I put alot of street miles on it and that is hard on the roller lifters. I dont need to worry about a roller lifter breaking if I dont change them in a few thousand miles. The flat tappet cam will be hardened (nitride) and I will use EDM lifters so I hope not to wipe any lobes. And thanks for the kind replies. Ron
