Re: How does Easy Off remove anodize on grills ?
[Re: 64 Savoy]
#855434
11/19/10 11:10 AM
11/19/10 11:10 AM
67Monaco
33950
photo frisket is like clear masking tape, but it comes in sheets. for covering a larger area, then trimming away what you dont need. i also use blue painters tape, and visqueen if i dont have the frisket. i like the frisket, because it's transparent, so you can easily see what you are trimming against, and if there's an air bubble, it's also quite visible. the paints you choose, should be compatible. if you use SEM trim black, use SEM clear, etc. just depends if you are going to use an airbrush, rattle cans or spray gun, and what you're comfortable shooting. i like SEM or PPG, but really anything you are happy with, is best. as mentioned above, i also will use a small detail brush, for getting into tight spots, or detailing emblems, etc.
Thanks. Now to find this stuff!!
Easy as pie..
http://www.dickblick.com/products/badger...mckw=25203-1901
