Re: 1997 360 motor smoking issue, any ideas?
[Re: RapidRobert]
#849921
11/09/10 07:41 PM
11/09/10 07:41 PM
Posts: 1,941 South Jersey
6packattack
South Jersey
any ideas?
I'm thinking intake gasket again. I toss the front/rear seals as they can be too thick & hold the intake up a very slight bit too high but they tend to make the front water port(s) leak after time but mainly in your case I'd suggest a thick/wide carefully placed swath of clear silicone instead (front & rear)instead of the gaskets, on brake kleen(ed) surfaces & let it sit up overnight and on the intake/head ports on the side I use composite side gaskets w Permatex sealer rather than the tin ones though I've used the tin (w sealer not dry) EDIT if this is a magnum torque intake bolts 1-4 in 12 INCH lb increments (in order 1 thru 4 (6) times) to 72 inch lbs then the remaining bolts to 72 inch lbs in 1 shot starting w #5 (to # 12) in order. Then (re)tighten all bolts (in order 1-12) to 72 inch lbs then repeat on 1-12 again
He replaced the belly gasket, tightened manifold to specs above, used silicone. I don;t think that explains why the 4 plugs on driver side still are wet? were checking the pass side soon. We also replaced the rear intake bolts being the original bolt heads were completely gone. That was an hours worth of time just removing them haha...
Entire Thread
6packattack
11/09/10 10:26 PM
RapidRobert
11/09/10 10:42 PM
6packattack
11/09/10 11:41 PM
superwrench
11/10/10 12:49 AM
Mirada440
11/10/10 12:53 AM
6packattack
11/11/10 09:01 PM
6packattack
11/17/10 01:04 AM
goldmember
11/09/10 10:49 PM
superwrench
11/09/10 11:04 PM
6packattack
11/09/10 11:19 PM
5spdcuda
11/09/10 10:50 PM
