Yeah you pull the outer bearing.Then put the nut back on the spindle.and angle the drum or rotor as you pull it over the nut.The inner bearing and seal will pop out and stay on the spindle.If they were making noise you probally need bearings and races.The races have to be pounded out.They are a light press fit.Rocky
Chrysler Firepower
