My buddies 07 Ram 1500 with the V6 just started running bad out of the blue? He was about 2 miles from home It was running fine then all of a sudden started coughing ,spitting and sputtering, he depressed the clutch and it seemed to smooth out but in gear it didn't run right! when it happened the ETC light began flashing(electronic throttle control),he made it into the parking lot and let it idle , sounded like it was missing real bad ( through the exaust) Anyway he shut it off then restarted it and the problem disappeared? You guys know of any similar problems or have any advise on what to look for?
Thanks in advance!
