thanks guys.its chopped 5",took 6" off the rockers,channeled 4",and when i chopped it i moved the cowl back aprox 3" so the roof would line back up,then took the same amount off the rear of the doors.i built the chassis and used a speedway 6"drop front axle kit.i used a 68 dart manual steering box and set it up for cowl steering.used a 9 1/4" posi .plans for the engine are a 512 stroker kit and aluminum heads with a comp hyd roller.
i really like the willys clip on the dodge.
