most times i have removed a tranz,it had them on the bolt against the mount then tranz
I allways thought it was cause the bolts are a little to long and it keeps it from bottoming out in the tranz mount holes..which are blind and can strip/crack the tail housing
never seen them between the tranz and mount flange
74 is the spool mount correct?
