It may cause problems. The only way to know for sure is to measure the angles at both ends of the drive shaft, or you can just put in a spacer and find out. If the lack of spacer is the problem, it will show up by the time you reach highway speed. If you notice the vibration before reaching speed, slow down and remove the spacer. Go to a drivline shop and bite the bullet.
