69 B body.
Front of car is on jack stands on the frame. Wheels off. K-member supported by floor jack for safety.
I've:
Removed the pins behind the torsion bars that are located in the cross-member.
Backed out the bolts in the lower control arms that control ride height. I believe this relieves tension of the torsion bars.
Bought a torsion bar tool, attached it to one of the cars and have hammered toward the rear of the car.
It didn't budge, so I wanted to check with you guys to see if I'm doing something wrong.
The front suspension should be hanging down for torsion bar removal, correct?
Tips? Suggestions? Bigger hammer?
-dan
