Check for 68-69 windshield gasket and stainless, I believe 67 only used the plastichrome that shrank and broke. Or use pieces of the original plastichrome trim as clips,we had to grind them to fit the back of trim we used off of a dart or valiant also had to cut the stainless down but it did fit decent. this was on my dads 67 cuda,he didn't change gaskets so this is how we made it work. or you could always go with 68-69 gasket ,clips and trim. good luck
