Just get some Home Depot/Lowes self-stick foam weatherstripping tape...comes in different thickness (find one similar to the glass tape/adhesive you'll use) and stick it to the glass before you lay it in. It is only sticky on one side so won't bother the primer.
Works perfect and still has a little give to it while you are working around the glass.
I like the idea for the self stick foam. Thanks.
