Launching with leafs is all in 2 things good movement in the front end(try for 5" minimum) and SHOCKS... good shocks... its in the control of the body raising cant have it going up too fast.... while alot of guys use the Rancho 9 way on the rear alot of times you will be at max or near max on the settings
