I have had an issue with no dash lights for quite some time now i installed a harness that was in better shape then mine still no lights. While looking around today i found out that at the fuse box at no point is the terminal which is labeled instrument and something else i forget is never hot not in the acc position not in the run and not with the key out like the taillights etc. So Im beginning wonder is there something thta makes this terminal hot that im missing I also checked it with the head lights on, no change. If anyone knows what ignites that terminal or maybe if its suppose to be that way (doubtful) that would be of great help to me. Thanks again moparts members
