on my Duster, with Hedman Hedders I thought it'd be a fun change to try header mufflers. so I got some Purple Hornies, with intentions of adding pipes to the and out the back in a month or so. I was caught off guard when i realized the headers do hang closer toward the center of the car, causing these header mufflers to lay against the curve of the cross member. it looks like if the mufflers angled inward about 10 degrees it would be cool. I'm curious if it's a big deal to properly bend the neck on the muffler to make this clearance or should I just go with a regular headpipe set-up?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
