I was told the .840 bars in a big car (B body) could be an issue as far as longevity on the street ?
I "ground" my bump stops down on my grinder,,I know some guys remove them all together,,i wanted to have at least some portion of cushion/rubber there.
How much travel do you have on the front end,,,i was told you should have 4-5",,, for me,,to achieve this,,,I had to lower the front end. If i recall the front end ride height on the "X" is set up for the street,,but I love the stance myself...
I have QA-1's and some Caltrac's,,,if were ever at the track together,,,your welcome to swap them on your car and try em....
ps,,Huge fan of the "X"
