no idea I've never checked the lash on a hydro cammed BB mopar using stock valve train. They should move a smidge and that's it. You might want to prime the engine using a drill and priming tool the check them again. If the heads were cut you'd have issues with them hanging open. More likely the vavle job was not done to well and the seats are cut wrong or something.
