I understand that the lifter fills with oil so are you saying that the lash does not matter as long as the lifter does not bottom out like a solid lifter would? Is all the varience caused by rocker arms being different? Maybe this is just common mopar valvetrain and I'm used to much closer tollerance with other motors I have built.
