Thanks! I actually have an extra VR on hand, and I will try that first after double checking the wiring.
I was thinking it was the wire I added from the alternator stud to the starter relay as it bypasses the VR... Would you guys recommend that I keep this wire there, or no need for it? I did add a fusible link to it.
