no it is perfect on oil checked that. it smokes really bad on acceleration and some while idling as well.when cruising it is a faint light smoke coming from it. plugs are a little dirty but not too bad. it is coming from tailpipes. it is a blue smoke so i know it is oil burning and i havent done a compression test. i have been told it will smoke until the piston rings seal but it has about 150 miles and seems like to much smoke to me. any more help would be great i dont know alot about this stuff and im trying to learn as get some help at the same time thank you
