you mentioned eddy heads ,if your trying to do it withe heads on ,forget it, the plug angle USUALLY wont allow it.
Why? Interference with the valves? - and if so, why can't he just disconnect the valve train on # 1 cyl?
the tool goes in the plug hole at too horizontal of an angle.
Yep...I did it and just bent the piston stop (the style that goes in the spark plug hole). It did work once it bent though....lol.
