Doc, good point on the sensors. There is no leakage on this neon. I do have a question; this neon was given to me for FREE. when I picked it up, the car would not move in any gear. The owner of it was told it was the pump, so he didn't want to fix it.
I winched it on my trailer and took it home where it sat for 6 months until last week. I pulled it in the shop and pulled one of the lines to the rad cooler to see if there was any fluid being pumped. And there was, so I put that oil back in it and checked the level, it was low about a quart, so I topped it off. And then drove the car oput of the shop....all the gears work fine...???? I have tested this car for about 20 miles and it shifts perfectly. Your thoughts???
I just finished an trans oil and filter change. There was sludge and metal shavings on the magnet.
