Can I use magnum roller lifters and pushrods in my LA without any mods? With stock LA heads? What about the magnum cams?
if it's a roller block, lifters yes, pushrods no, they're different length than LA--unless you switch to mag heads/rockers also. in fact, the mag lifters supersceded the original lifters as replacement parts (go on rockauto, a magnum and '86 5th ave spec the same parts). magnum cams, maybe. OEM ones, probably not, as they don't have (or at least the one I had in my hands) the holes in the #2 & #4 journals for oiling. you could have the holes drilled, or maybe even have a groove cut in those journals (would provide continuous vs. metered oil) to get oil to the heads. most aftermarket magnum cam's I've seen have the oil holes. any aftermarket roller cam will work with OEM lifters...
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
