bone stock typical 84 318 2 bbl holley
mopar ignition, new ECU, new dist, new coil.
Engine will only run if the choke is 1/2 on, it dies as soon as it is leaned out. Originally thought it was sucking air from a hole in the sending unit, but that didn't do the trick.
Car acts like its not getting fuel, but when I take the fuel filter off, it flows gas. This happened on a 75 mile trek to buy parts, and it just started missing and losing power after an hour on the road.
Carb related? or another junk ECU from autozone?
