Where I plug into the trailer(underneath the trailer)
is a plug box so its either plugged into the gen OR
plugged into the shop... I cant do both... only 1
plug
EDIT or I can plug in at the track if they have power
The problem is you half to isolate the nutrals via dis connect or tranfer switch while pluged into city power or you back fead the gen. through the nutrals,and the city power company always wins!!!
The gen CANT be plugged in if I'm on HOUSE power
2 separate wire hook ups(I have to unplug the gen
if I want to use the house power)... basically I
have a extension core going to the one and only inlet
from the gen to the trailer(its underneath) so its
a either or, not both
