I have an onan 6500 witch I installed this last winter. I also installed a trickle charger to keep the battery up and it is wired into the panel in the trailer,caution though you need an rv transfer switch If pluging into household power.I bought a RV auto transfer switch for 140 bucks.
Where I plug into the trailer(underneath the trailer)
is a plug box so its either plugged into the gen OR
plugged into the shop... I cant do both... only 1
plug
EDIT or I can plug in at the track if they have power
