When driving all is good. Sitting in traffic (Woodward DreamCruise) the engine starts to bog and will stall, but will immediately re-start. As long as the rpms are higher it's OK. Put it in gear (auto) and it bogs and stalls again, and the process repeats.
Have him install a clear plastic or glass fuel filter. Could be a weak fuel pump. Better yet have him install a fuel pressure guage.
I'm in the process of installing a Carter mechanical "street" pump as the stock LA pump is not keeping up at high rpm's. When my 360 is hot, it also sputters and tries to quit at or near idle. A quick look at my clear gas filter shows the filter is empty with only irregular spurts of gas entering the filter.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
