how quiet (or noisy) are the fuel pumps that come with the kit?
Noisy enough to hear if you have a quiet exhaust. If outside the tank, I recommend insulating the mount.
can an inside the tank pump be used? how about using a stock GM efi pump?
Any one know if you can mount the "kit" pump in the tank? I have the 307502 kit.
Thanks,
64.............
the pump that comes in the kit can only be externally mounted.
I have a full TTI exhaust system on my car and can only hear the rail mount pump that comes in the kit when the car is not running , in contrast the Holley blue pump I used to have on the car I could hear all the time.
The pump that comes in the kit does have an insulating sleeve and rubber coated mounts.
