Need some help please. There are different types of clips to hold the charger SE roof trim in place.The white plastic clips that mounted on the roof studs, the black plastic clips that mounted using screws and the metal spring clips that are bolted on. I can't remember what type was used on the two lower holes located under the louvers to hold that piece of trim in place
