I just figured out that my innova 3100 will work with the intrepid but not the caliber. So I need to check into a new tester. I removed the line going to the fuel rail and no fuel came out. Not sure if that is the way to test the fuel pressure or not.
Will try to figure out how to get the codes out tonight.
Craig
