I wonder if you have to cut the cross member on a b-body to get a tko to fit? Doesn't the new Quicktime bell allow you to bolt up a TKO? This might make it a little easier for the DIYer.
I have $3500 in my kit. The only extras were the disc ($69) and T/O bearing.
If you look at the pics on Keislers site, they have the shifter in the middle position and the rearmost (mustang) position has been notched and a custom sheetmetal cover RTV'ed on which must be to clear the T-bar crossmember Arch. Probably the DIY could accomplish the same easily with access to a mill.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
