Well, if your wallet wasn't empty from purchasing the "thunder juice", I'm guessing it would be after expermenting with it. Just pouring it in would be disasterious. It is mostly an oxygen carrying agent. It would have a lot of the same effects as spraying no2 with out adding more fuel or changing timing, compression ect. Kinda like when you pull the handle on a cutting torch.
Brian
