boy, I think some of us should not talk about things when we are not sure if we have the correct answer.
Please at the very least check and adjust toe. It is the most tire wearing adjustment if off. You are basically scrubbing the tires when you have the toe off.
For those who think change in ride height does not change toe, according to test done by Hotchkis toe can change as much as 1 inch during the up and down travel of the suspension!
Although this video is about bump steer it basically tells you the toe is in a different spot depending on where the suspension (ride height) is.
http://www.youtube.com/watch?v=VzxPWrdPlt0
