Also, why would I need to remove the steering wheel colum studs? I was just going to loosen them to bring the wheel down some so I could tip the dash.
They can still get in the way...especially if the front seat or steering wheel are not letting the column drop far enough.
Come to think of it, I don't think you'd be able to swing the assembly down at all with them in place.
