the truck style coil packs from the earlier years can be changed over to the newer style dual plug on single coil system. its a much cleaner look. lets you lose the long plug wires.
kits run in the 300-350 range.
comes with eight coil packs. the valve covers..pig tail ect..everything one would need.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
