Thanks for all the responses. I tried the online computer dyno to try to get an idea on how much torque vs horsepower the cams would give (ball park). All are in a good range,all will give, according to the program, 370 to 397 hp and 440 to 480 lbs torque, but the bigger 280 cam gives about 29 hp over the smaller 262 cam, and the smaller cam gives about 40 lbs of torque over the biggest. The Hughes cam and Voodoo cam are in between.
What is better for a cruiser? gain 40 lbs torque or 27 hp? Maybe a better question is about how much torque does a 383 need to put out to push the Road Runner with ease?
Thanks Carl
torque. where is the 27HP advantage? probably over 5000 RPM. how often do you buzz your motor up there? where is the 40 lb-ft advantage? probably in the 3000-3500 RPM range, where you're at a lot more. the midrange torque advantage also translates to a midrange HP advantage. I'd use a comp XE262 or voodoo 60302 if looking at an off the shelf grind.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
