Someone was supposed to be making a BBJ stud in the SBJ housing but they are expensive.
someone posted the co name that made them but I lost it. Going the other way I would think a correct dimention sleeve would be safe . If you UCA bushings were good & you kept the same ride height it would certainly save having to realign.
